What's happened to relay.plus.net?
- Re: What's happened to relay.plus.net?
03-11-2011 4:33 PM
Has Plusnet changed something?
thanks.
03-11-2011 4:53 PM
03-11-2011 4:54 PM
03-11-2011 4:54 PM
http://community.plus.net/forum/index.php/topic,99553.0.html
http://community.plus.net/forum/index.php/topic,99023.0.html
03-11-2011 4:59 PM
Quote from: Chris Are you getting any error messages at all? Have you tried sending a mail from a standalone mail client such as Outlook or Thunderbird?
I have PRTG Network monitor configured to send via relay.plus.net which I know worked a couple of weeks ago says "Error sending "Email": Connection failed ("relay.plus.net")" and a remote notification app on my WHS says "Error: Failure sending mail".
I have outlook configured as IMAP as I use Gmail.
03-11-2011 5:01 PM
Quote from: spraxyt Are you aware of the well-publicised change of spam and virus checking to Cloudmark (Plusnet look to the Clouds for Email Security Solution that took place progressively through October?
Nope. I didn't receive any notification about this from Plusnet. Is this stopping me from using relay.plus.net? What do I use instead?
03-11-2011 5:11 PM
Quote from: wyerd
You might want to consider subscribing to our Service Status feed (see my sig).
You can still send via relay.plus.net but there's a possibility that our new outbound or inbound anti-spam appliances are now rejected the messages as spam.
I suppose you could configure PRTG to send via Gmail's SMTP server?
Perhaps you could PM me a full copy of one of your old emails (complete with headers)?
Alternatively try copying the contents of an old email you were able to send into a standalone email client and see if you can send that via our relay servers?
03-11-2011 5:35 PM
Quote from: Bob Perhaps you could PM me a full copy of one of your old emails (complete with headers)?
PM Sent
03-11-2011 10:34 PM
Mails are now routing through relay.plus.net .
Thanks.
07-11-2011 4:33 PM
