Webmail - using reply
- Webmail - using reply
11-08-2013 12:29 PM
Using Webmail, Can anyone tell me please how to EXCLUDE the original message from my reply?
I'd like to set "Exclude original" as a default.
Tx.
Tx.
Message 1 of 2
(843 Views)
1 REPLY 1
Re: Webmail - using reply
11-08-2013 3:24 PM
I think the only options are starting the reply above or below the original - so it isn't possible to omit it completely..
A relatively easy workaround is, before you type anything, to right-click the message pane and click 'select all'. Then press the 'delete' key or do another right-click and select 'delete'.
David
Message 2 of 2
(339 Views)
