Webmail redirect
- Webmail redirect
Webmail redirect
07-06-2012 8:56 AM
I think somebody has set up the redirect from the old email page wrongly. It seems to redirect to itself.
https://webmail.plus.net/src/login.php
Message 1 of 3
(994 Views)
2 REPLIES 2
Re: Webmail redirect
07-06-2012 11:19 AM
That URL is from Squirrelmail before it was moved, and it appears to redirect to the root, probably because the file was not found.
You'll need to update any bookmarks to the old (basic) webmail as it moved when it was replaced with the new (advanced) one..
The old (basic) webmail is now at https://webmail.plus.net/squirrelmail/src/login.php
Message 2 of 3
(427 Views)
09-06-2012 8:57 AM
It's been fixed now. Thanks to whoever fixed it.
Message 3 of 3
(427 Views)
