Webmail not available.
chuffchuff
I keep getting this when I try to log into my webmail.
All other email accounts are working fine.
Any suggestions, thanks.
17 REPLIES 17
tmoscrop
Re: Webmail not available.
Are you able to browse other sites, and does this happen on more than one device?
chuffchuff
All other sites are available to browse.
I do not have any other devices to use to test availability.
My pc is running fine.
No viruses etc.
chuffchuff
Just managaed to log into my account, all my messages, sent, received,
saved, deleted are gone.
No worries.
I'll contact Customer Services & have the web mail deleted.
Too much hassle.
Thanks for replying.
Chuffers.
Anotherone
Champion
Fixes: 21
https://webmail.plus.net/ does seem to be very slow loading at the moment and I got a connection reset error whilst logging in and then it took ages to load the mail as well. So there is something up with the Servers by the looks of it.
I've just logged into WebMail and played about with a few settings and it was very slow to save my settings. I also got a connection reset error at one point.
KevH
Just to add my voice, being refused connection since 8am this morning. Have also tried connecting using my mobile using mobile data.
Message is "Login Failed"
Anotherone
Champion
Fixes: 21
I wonder if @bobpullen is aware, he's no doubt running around like a bluewotsit fly at the moment anyway Lips_are_sealed
chuffchuff
Is plusnet assist available? I cannot download it, access it, use the guides, find out whether
it will help me should I ever need it or actually access it to download it.
Separately, why is there two of me now?
Before the transition to the new site I was just "Chuff Chuff";
now I am "ChuffChuff"  "Chuff Chuff".
No objection really, just wondering whether I will be
"ChuffChuff"  "Chuff Chuff" "ChuffChuff" soon or not?
bobpullen
Fixes: 316
Those of you having problems with Webmail, are you all browsing to the site from non-Plusnet connections?
Nope, I'm currently using my PlusNet connection.
bobpullen
Fixes: 316
Thanks. We've an incident raised and we're looking into it (ref: 91363).
chuffchuff
No, I am using Plusnet.
I just ran a speed test on my standard broadband connection and it came back with a
download speed of 17.72 mbps  & an upload speed of 1.12 mbps, which seems OK to me
but everything on the PlusNet site seems to be either not connecting or timing out.
KevH
It is still broken this morning. How are we to check on the status of incident 91363? If you check the Service Status page it says there are no issues with email. Perhaps this issue isn't a priority or only a few of us are affected? An update would be appreciated.
It works for me, the site appears in less than a second and logging in takes a similar amount of time on ADSL 20CN
