Webmail - multi-part message in MIME format.
- Re: Webmail - multi-part message in MIME format.
29-08-2014 4:33 PM
How can I get the email to show correctly in webmail while I'm away from my main PC.
Thanks.
Forum Moderator and Customer
29-08-2014 4:53 PM
The problem has been raised a few times before (e.g. https://community.plus.net/forum/index.php/topic,128414.0.html)
From looking into it previously, it's possible that the problem has been fixed in a newer version of RoundCube, but we'll have to wait for PlusNet to upgrade to see if it helps.
29-08-2014 5:09 PM
It's not a major issue as I will be back home tomorrow anyway.
31-08-2014 9:44 PM
31-08-2014 10:14 PM
I just wondered whether I had missed a setting in Webmail.
Thanks anyway.
04-09-2014 5:34 PM
Quote from: kmilburn From looking into it previously, it's possible that the problem has been fixed in a newer version of RoundCube, but we'll have to wait for PlusNet to upgrade to see if it helps.
If I ever receive an email from DPD at any point then I'll let you know. I sometimes use the latest Roundcube install.
