Webmail icon problem
- Re: cant get the new webmail user-name and passwor...
17-04-2012 9:42 AM
@ Bob Pullen, these are the part showing menu icons I mentioned on the Community News Site about the new webmail, they are the same whatever font size, in Camino .
Same before and after RP mod.
In Safari, I can see them properly, thought extremely small, if I make Safari fonts really really small, just about too small to read
In Firefox & Chrome, I cannot see the icons below the main ones whatever the font size.
Apple OSX 10.7.3
Apple OSX 10.7.3
Message 1 of 7
(2,000 Views)
6 REPLIES 6
Re: cant get the new webmail user-name and password saved
17-04-2012 2:27 PM
@ PlusComUK: What setting have you got in Camino for minimum font size? I'm only seeing that overlapping problem when it's set at 14 or above.
That's RPM to you!!
Message 2 of 7
(697 Views)
17-04-2012 3:38 PM
It's a weird sort of repeating the icons, displaced by one icon !
The top icons don't disappear, as I thought they would if not enough space to display.
The repeats seem to always be there, just not visible for small font size.
My normal 18pt
24pt
14pt
12pt
It's also the same sort of repeating effect in Safari...
The same minimum font sizes as above show exactly the same effect in Safari
Why are the icons repeated ?
My normal 18pt
24pt
14pt
12pt
Message 3 of 7
(697 Views)
17-04-2012 5:23 PM
Maybe this icon issue should be split off into a new thread on its own. Moderator, if you please.
That's RPM to you!!
Message 4 of 7
(697 Views)
Re: Webmail icon problem
17-04-2012 6:09 PM
Split off and title changed - if a post is in the wrong slot just advise
Message 5 of 7
(697 Views)
18-04-2012 11:04 PM
Right, an update to this issue. I've tested on Camino 2.1.2, Firefox 11.0, Google Chrome 18.0 and Safari 5.1.5 - all exhibit this strange behaviour when large font sizes are set (either by setting a minimum size or zooming text only).
So this isn't limited to Camino only, from what I've seen. I've not had time to check what happens in Win7 but I would expect to see it there also. As to why it's happening, I'm not too clear on the cause, maybe something within the stylesheet.
That's RPM to you!!
Message 6 of 7
(697 Views)
20-04-2012 4:54 AM
FF 11.0 Fonts settings are all default. I can get the overlap problem if I zoom in a couple of times.
Message 7 of 7
(697 Views)
