Webmail filtering isn't working properly
- Re: Webmail filtering isn't working properly
13-05-2014 5:36 PM
In my webmail inbox (RoundCube) there are 12 dispersed emails from eBay (out of 87 emails in total) - I thought I'd put eBay into the search box to go through them quickly.
However only three entries were found when I hit return - and two of those were other emails sent by me containing eBay in the message body.
So why was only 1 out of the 12 emails picked up in the search? It's set to "entire message" with all boxes ticked.
Most of the emails are from ebay@ebay.co.uk - putting ebay@ebay.co.uk into the search box comes up with nothing at all!
Clearly something is deficient somewhere...
Message 1 of 7
(1,700 Views)
6 REPLIES 6
26-05-2014 4:18 PM
45 views - no one expressing an opinion?
Message 2 of 7
(832 Views)
26-05-2014 4:20 PM
Just tried again in a totally different context.
I searched on "cross" and only got one result despite knowing there should be more.
However note the header on the attached screenshot - it says it found SEVENTEEN emails yet is only displaying one.
Is the search routine permanently broken? Does no one else use it?
EDIT - XP/FF29.0.1
EDIT - XP/FF29.0.1
Message 3 of 7
(832 Views)
26-05-2014 4:26 PM
Quote from: drj In my webmail inbox (RoundCube) there are 12 dispersed emails from eBay (out of 87 emails in total) - I thought I'd put eBay into the search box to go through them quickly.
I've re-run the "ebay" search and found the same problem - eleven emails displayed but it says it's found 33!
Message 4 of 7
(832 Views)
26-05-2014 10:57 PM
Sorry drj, can't really comment on this one as I'm not using RoundCube much and certainly never had the need to use the search filtering within it.
Anyway, not much help for you but I am following.
That's RPM to you!!
Message 5 of 7
(832 Views)
27-05-2014 1:46 PM
Oh, just had a thought, could the search be linked to page display? On the screen shots you've added unfortunately it doesn't show if pages are involved or not. So it might be possibly showing only the results on that particular page of emails you're viewing.
Should be quite easy to discount this idea, so I await your response.
That's RPM to you!!
Message 6 of 7
(832 Views)
27-05-2014 6:32 PM
No - the count is currently showing 173 emails on one page - when I did the screenshots it was about 130 or so but I've had a deluge of emails in from eBay in the last two days
Message 7 of 7
(832 Views)
