Webmail error - Failed to set sender invalid domain (no MX or A record)
PJDa
Hi
New to PlusNet and trying to setup my mail account - I can login to webmail but when I try and send an email I get the error
'SMTP Error (550): Failed to set sender "<name@username.plus.com" (<name@username.plus.com> sender rejected - invalid domain (no MX or A record))'
I see this error was reported on freenetname domain but I am on username.plus.com domain.
Does anyone have any suggestions?
5 REPLIES 5
TheMightyAJ
Fixes: 126
Re: Webmail error - Failed to set sender invalid domain (no MX or A record)
Hi @PJDa,
I'm sorry to hear that you've encountered this issue. If you try setting your mailbox up on a client, does the same issue occur?
 Alex H
PJDa
Thx for responding - I have just tried it again from Webmail and message was sent successfully - guess there was something that took some time to be set up correctly.
Fixes: 1,641
Thanks for getting back to us @PJDa
It can generally take up to 4 hours. Let us know if there's anything else you'd need help with.
Fixes: 236
Are you a brand new Plusnet user?
If yes, you cannot access the SMTP server until AFTER your service goes live.
PJDa
Hi
Thanks for the response.  I am a brand new PlusNet broadband user (and hence to the email aspects of PlusNet).  My service started on 8th Dec 2021 and I got the email error on 10th Dec 2021.  I had expected things to be up and running by then but guess there might have been some weekend glitches before normal service resumed.
