Webmail and co.uk
- Webmail and co.uk
Webmail and co.uk
13-02-2013 11:59 AM
If I have a co.uk website hosted on my account with email accounts attached to it can I use webmail to access these accounts or do they need to be a plus.com for webmail?
Message 1 of 3
(729 Views)
2 REPLIES 2
Re: Webmail and co.uk
13-02-2013 12:39 PM
Mail sent to hosted domain addresses is delivered to the equivalent username.plus.com mailbox and can be accessed by logging in to webmail using the appropriate username-based mailbox and password information.
When sending mail from that mailbox using webmail your can define whatever identities (sender addresses) you wish including domain-based addresses. You choose which identity you want to be the default. Identities in webmail are set in the Identities tab in Personal Settings.
David
Message 2 of 3
(96 Views)
13-02-2013 1:29 PM
Message 3 of 3
(96 Views)
