Webmail Password Reset not working ?
t72bogie
I have a legacy madasafish/totalise email that ive been using since the 90s.
I use the Plusnet webmail client and I want to change the password on my account
I go to the madasafish link for password recovery and it appears to work, yet I never receive the password reset email .
Anyone have any suggestions on how to change your password if you are just a webmail customer ?
thanks
16 REPLIES 16
BD
Fixes: 86
Re: Webmail Password Reset not working ?
Hi and welcome to the Community Forums,
I've dropped you a private message in how we can get to the bottom of this for you.
Kind Regards,
Ben
t72bogie
thanks Ben for prompt support, all sorted now
cheers
JulieAcey
I have exaclty the same issue - an old totalise account and i want to change the password but can not find a way to do it.  Any advice?
Kind Regards,
Ben
Kind Regards,
Ben
oldnovo
I have forgotten/need to reset the password to an ic24 (madasafish) webmail account. I have got nowhere trying to do this through my Plusnet account. You seem to have been able to help people with a similar problem.
Fixes: 1,600
Hi there.
You should be able to reset your default mailbox password using this link: https://secure.madasafish.com/forgotpassword/
hario325
I have a totalise.co.uk email address on Just Mail
In the last week or so my iPhone X has stopped picking up emails on the totalise email address, it can send, but not receive.  It works fine on wifi but not on Vodaphone 3G/4G.
It receives email on other email addresses whether on wifi or 3G/4G.  I am on pop3 settings that have worked for years and years
Any advice
Tags (2)
spraxyt
Resting Legend
Fixes: 75
@hario325 Welcome to the forum. Smiley
I think the problem you are experiencing is similar to that raised in topic https://community.plus.net/t5/Email/freenetname-no-send-receive-for-2-days/m-p/1511873#M22413 with the freenetname server. In your case the incoming mail server mail.totalise.co.uk is not reachable from outside the Plusnet network. tracert succeeds from my home connection but stops at colindale or faraday from outside.
[~ $] traceroute mail.totalise.co.uk
traceroute to mail.totalise.co.uk (212.159.8.240), 30 hops max, 60 byte packets
 6  LINX1.ukcore.BT.net (195.66.224.11)  5.445 ms  4.187 ms  4.401 ms
 7  62.172.103.136 (62.172.103.136)  5.658 ms
    core1-hu0-17-0-0.colindale.ukcore.bt.net (62.172.103.142)  5.537 ms
    core3-hu0-2-0-6.faraday.ukcore.bt.net (62.6.201.194)  5.421 ms
 8  * * *
 9  * * *
10  * * *
11  * * *
Plusnet need to take a look at this. @bobpullen
David
hario325
Hello Bob
New to this - how do I do that?  Can I do that through here?
On a live chat (that was cut off) the other day they instantly blamed Vodafone or IPhone.
bobpullen
Fixes: 316
As mentioned in the other thread, I suspect the traceroute observation is a red herring. This is from a Vodafone 4G connection:
> tracert mail.totalise.co.uk
Tracing route to mail.totalise.co.uk [212.159.9.240]
over a maximum of 30 hops:
  1     2 ms     2 ms     2 ms  192.168.43.1
  2     *        *        *     Request timed out.
  3    48 ms    33 ms    39 ms  192.168.213.21
  4    42 ms    37 ms    38 ms  192.168.213.22
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7    45 ms    53 ms    44 ms  63.130.105.130
  8    67 ms    38 ms    38 ms  ae11-100-xcr1.hex.cw.net [195.89.96.1]
  9    45 ms    32 ms    38 ms  ae18-xcr1.lnd.cw.net [195.2.24.157]
 10    62 ms    44 ms   105 ms  ae15-xcr1.lns.cw.net [195.2.30.114]
 11    36 ms    32 ms    38 ms  t2c3-ae1-0.uk-lon1.eu.bt.net [166.49.211.253]
 12    46 ms    46 ms    45 ms  166-49-211-237.eu.bt.net [166.49.211.237]
 13    78 ms    44 ms    36 ms  core2-hu0-17-0-6.colindale.ukcore.bt.net [195.99.127.86]
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *     ^C
And I can communicate with the POP3 server without any issues:
> telnet mail.totalise.co.uk 110
+OK Hello there.
user [redacted]
+OK Password required.
pass [redacted]
+OK logged in.
stat
+OK 256 48078963
I'll ask about and see if any changes were made our side a couple of days ago, but from what I can establish, things are working as they always have Huh
hario325
Hi Bob/Dave
Apologies for any forum etiquette faux paus as I am brand new to this.
I cannot raise a support ticket @bobpullen as I am in an endless loop of logging in to Madasafish and then clicking on raise a support ticket and being asked to login again.
Totalise email picks up on my iPhone X mail app when on wifi (Wifi with TalkTalk) but not when I leave the house and on 3/4G (Vodafone)
Was fine until this week.
Please can someone from @plusnet help?
Thank you Paul
Kelly
Fixes: 9
It looks like it's something to do with the Vodaphone network, rather than specific to us.   Do we know if their dongles support pop3 access?
Kelly Dorset
Ex-Broadband Service Manager
t72bogie
hi Ben
I need a password reset again and the usual madasafish link isnt working for me or perhaps the backup address its sending to isnt the correct one
please can you drop me a line
thanks
Hamishmg
Having the same issue; could you let me know how you solved it?
regards
Phil
t72bogie
Someone from tech support reset it for me. The issue was that my secondary email in my account for the reset messages to go to was the same address (plus net).
Since then i use my other email address for password reset messages
