Web Mail not working with old Captcha V1
- Re: Web Mail not working with old Captcha V1
26-11-2018 7:42 PM - edited 26-11-2018 7:54 PM
When the Captcha comes up it is out of date
Unable to use due to Captcha V1 out of date and shut down.
26-11-2018 9:19 PM - edited 26-11-2018 9:30 PM
I don't get a Captcha when I log in..
Have tried typing in reCAPTCHA V1 IS SHUTDOWN
[edit] I've read typing in any word might work.
26-11-2018 9:24 PM
It comes up after making a few errors, clearly should be updated.
26-11-2018 9:29 PM
Found this.
"The reason why you are getting this error is because - “Any calls to the v1 API will not work after March 31, 2018.”
All the best
27-11-2018 9:15 AM
Hi @LifeonMars
I believe this is something we're aware of, but you should only see Captcha if you've typed in a password incorrectly too many times. A workaround is to leave it for an hour then try again, which should clear it and allow you to login normally.
Let us know if you have any further issues with this.
