Waitrose POP3 email problems
- Re: Waitrose POP3 email problems
15-12-2010 1:14 PM
I get the following error message:
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'xxxxxxxxxxxx@waitrose.com'. Subject 'test', Account: 'xxxxxxxxx', Server: 'smtpmail.waitrose.com', Protocol: SMTP, Server Response: '550 relay not permitted', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
I have replaced personal info with xxxxxxxxxxx
Webmail works and incoming messages are getting through.
Any ideas please?
15-12-2010 1:21 PM
I've asked Bob to have a look into this one, but that message is normally when you are trying to use an outgoing mail server that does not belong to your connection.
I take it you are currently connected to your Waitrose Broadband service?
15-12-2010 1:34 PM
$ telnet smtpmail.waitrose.com 25
Trying 212.159.8.242...
Connected to smtpmail.waitrose.com.
Escape character is '^]'.
220 smtp-proxy02.plus.net ESMTP Exim Wed, 15 Dec 2010 13:26:09 +0000
ehlo waitrose
250-smtp-proxy02.plus.net Hello waitrose [84.93.217.165]
250-SIZE 52428800
250-PIPELINING
250-AUTH LOGIN
250 HELP
mail from:<***************@waitrose.com>
250 OK
rcpt to:<support@plus.net>
250 Accepted
data
354 Enter message, ending with "." on a line by itself
subject:test
250 OK id=1PSrNW-0002nn-F5
quit
221 smtp-proxy02.plus.net closing connection
You'll probably receive the auto-responder.
15-12-2010 2:27 PM
I have only a Waitrose PAYG account just so I could keep my Waitrose email address. My only BB connection is my PN one.
15-12-2010 3:36 PM
Open up a command prompt and type.
Press enter and you should get:
[quote author="Waitrose SMTP server"]220 smtp-proxy03.plus.net ESMTP Exim Wed, 15 Dec 2010 15:23:44 +0000
Type:
ehlo waitrose
[quote author="Waitrose SMTP server"]250-smtp-proxy03.plus.net Hello invalid.tld [80.229.xxx.xxx]
250-SIZE 52428800
250-PIPELINING
250-AUTH LOGIN
250 HELP
Type (substituting 'your_email_address' with your actual email address):
mail from:<your_email_address>
[quote author="Waitrose SMTP server"]250 OK
Type:
[quote author="Waitrose SMTP server"]250 Accepted
Type:
data
[quote author="Waitrose SMTP server"]354 Enter message, ending with "." on a line by itself
Type:
Test
Press enter, then type a single dot.
Press enter and you'll get something like this:
[quote author="Waitrose SMTP server"]250 OK id=1PStDn-0006qc-Q0
Type:
quit
Press enter and you should get something like this:
[quote author="Waitrose SMTP server"]221 smtp-proxy03.plus.net closing connection
Connection to host lost.
If any of the above fails, let me know at which point and what it says and we'll take it from there.
15-12-2010 5:20 PM
Bob,
After rcpt to:<support@plus.net> I get 500 relay not accepted
15-12-2010 5:28 PM
15-12-2010 10:18 PM
Will be interesting to see whether or not you have problems the next time you're assigned a similar IP?
16-12-2010 8:01 AM
edit: I'm still on 91.125xxx this morning and it's still working!
Watch this space
