VPN
kimphot
VPN
I use metronet email and when I installed a VPN I couldn't send emails. The VPN guys gave me some code, servers settings, to add to their code and all worked. I have now added Plusnet email to my artillary, with view to ending my Metronet email, and I have the same problem again, can't send email from the plusnet email.
I have found these settings:
To set standard DNS server addressesTo set alternative DNS server addressesTo set Plusnet Safeguard DNS server addresses
Primary212.159.13.49
Secondary212.159.13.50
Primary212.159.6.9
Secondary212.159.6.10
Primary213.120.234.42
Secondary213.120.234.42
The Metronet code mentioned above comprises four lines, is it the top four I need for Plusnet or all six? Or are they the incorrect settings? If so where do I find the correct code?
3 REPLIES 3
Fixes: 356
Re: VPN
You will need to set SMTP authentication when sending via the VPN
kimphot
Re: VPN
Thank you for your input, but that doesn't fix it!
kimphot
Re: VPN
I have fixed the problem. In addition to the suggestion received earlier it also required
route 212.159.13.49 255.255.255.255 net_gateway
route 212.159.13.50 255.255.255.255 net_gateway
route 212.159.6.9 255.255.255.255 net_gateway
route 212.159.6.10 255.255.255.255 net_gateway
to be inserted in the .ovpn folder.
It all works ago now.
