.Uusername and password
- Re: .Uusername and password
28-10-2013 3:41 PM
Hi
Can anyone tell me why my username and password works OK on here but if I use it on the Members centre it does not work.
Message 1 of 4
(1,017 Views)
3 REPLIES 3
28-10-2013 3:58 PM
different password and possibly - depending on how you set up your username here different username
Message 2 of 4
(282 Views)
28-10-2013 6:07 PM
I set p the same username and password. Can I change them for the members cebtre?
Message 3 of 4
(282 Views)
28-10-2013 6:12 PM
you can't change the username either here or in the member centre but you can change the password in both.
You should change at least one of them
I suggest going to the member centre and get a reminder of the password https://portal.plus.net/forgotpassword/
You can also change the display name on the forums via this link http://community.plus.net/forum/index.php?action=profile;u=15536;sa=account
Just one point - you posted this in the email section
Either it should be in the accounts and billing section or you are trying to login to webmail
Can you advise which it is
Message 4 of 4
(282 Views)
