Using mydomain without plusnet domain showing.
--chris--
I've just migrated to a new PC.
I use Outlook 2016 as my mail client. and with assistance from the PlusNet help team we finally set up the right servers to send/receive for my force9 mail. It is set up as IMAP now, previously was POP3.
Problem:
Any mail I send, arrives at the other end in the format of username@username.force9.co.uk   and I want it to say christopher@mydomain.co.uk
If I enter "christopher@mydomain.co.uk" in the From box, it still arrives with username@username.force9.co.uk on behalf of christopher@mydomain.co.uk
Question:
What settings do I change so that mail just arrives as christopher@mydomain.co.uk ?
Many thanks.
7 REPLIES 7
Fixes: 73
Re: Using mydomain without plusnet domain showing.
Welcome to the forums @--chris--
If i read your question right, to achieve what you want, you need to create another mailbox with the name of 'christopher' and send from that mailbox.
Don't know how/if that can be done on a 'force9' account though.
EDIT: Actually, I don't think you can do what you want, so ignore me.
Thrall
Seasoned Pro
Fixes: 20
@--chris-- You’d need to resetup your emails on Outlook with an email address of christopher@domain.co.uk not username@username.Force9.co.uk
Fixes: 184
@--chris--
Do emails addressed to christopher@mydomain.co.uk arrive?
--chris--
@Baldrick1 Yes they do 🙂
--chris--
John - Dutifully ignored @jab1
--chris--
Got it working, bit of trial and error as I had to go against the step by step instructions that the help team on twitter gave me, but in essence you're right @Thrall
The email address isn't directly connected to the log-on, although it appeared initially as if that had been the case.
Thanks for taking the time to reply.
Thrall
Seasoned Pro
Fixes: 20
Nice! Glad to see you’ve got this sorted now
