Using aquamail with relay.plus.net (or smtp.plus.net)
- Using aquamail with relay.plus.net (or smtp.plus.n...
27-10-2015 3:13 PM
The settings for the android native Email app are here:
http://www.plus.net/support/email/setup/android-setup.shtml
I'm about to try setting that up to test, but to save time...
I can't get them (outgoing email) to work on aquamail (using 3G, not home wifi).
Can someone post the exact outgoing settings they use successfully with plusnet
from Android, please? I have a Nexus 4.
Regards
John Maltby
Regards
John Maltby
Message 1 of 2
(662 Views)
1 REPLY 1
Re: Using aquamail with relay.plus.net (or smtp.plus.net)
27-10-2015 3:33 PM
In the Android settings have you entered a username and password AND disabled SSL/TLS?
Message 2 of 2
(458 Views)
