Thunderbird
Philippe
Thunderbird
Hello everyone,
From yesterday Thunderbird cannot get my messages.
Error message: Could not connect to server 127.0.0.1 connection refused.
I have checked all the connection setting. I cannot find the problem.
I have Windows 10 and Thunderbird 91.4.1
Any suggestions?
Thank you
Philippe
4 REPLIES 4
Fixes: 1,495
Re: Thunderbird
Moderators Note
This topic has been moved from Fibre to Email
adam945
Fixes: 113
Re: Thunderbird
Thanks for getting in touch @Philippe
Are these issues you're having specific to Thunderbird, or are you having issues with your webmail service as well?
 Adam
 Plusnet Help Team - Leeds
BrightonRock
Fixes: 8
Re: Thunderbird
@Philippe
I ran your error message through Google; you may have done so as well. I'm not at all sure that this is a Thunderbird (or Plusnet) problem.
Other people seem to have had this sort of problem in the past when it seemed to be related to an interaction with their antivirus package (the case that I found was AVG).  What anti-virus package you are using? It might be worth popping over to their user-group (if they have one) to see if others are reporting the problem there.
Fixes: 251
Re: Thunderbird
127.0.0.1 is the local host loop back address ... somewhat implying that the issue is within your own computer setup.  This is not the address of a Plusnet email server.
