Thunderbird problems
- Thunderbird problems
09-11-2012 8:40 PM
At first TB would not except my username and / or password although these credentials are exactly the same as i use to log in to the Plusnet member centre.
Now another problem has also reared its head! Now every time i click the 'done' button (this is shown as 'create account' on the Plusnet TB how-to page) i get a small dialog box pop up which proclaims 'Incoming server already exists' and it wont let me go any further!
I filled out the fields in the server details section.
I also get the following error message when i try to send email:
An error occurred while sending mail. The mail server responded: <XXXX@XXXXXXX.plus.com> sender rejected - invalid domain (no MX or A record). Please verify that your email address is correct in your Mail preferences and try again.
I replaced my email address with the X's ofcourse.
Message 1 of 2
(1,105 Views)
1 REPLY 1
Re: Thunderbird problems
10-11-2012 7:13 PM
Resolved!
Not sure what happened but i turned pc on today and everything works!
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Message 2 of 2
(334 Views)
