Thunderbird not responding and freezing
- Re: Thunderbird not responding and freezing
13-04-2014 11:48 AM
13-04-2014 1:18 PM
13-04-2014 3:03 PM
13-04-2014 9:21 PM
If it isn't, then close & re-open Tbird, then try disabling addons one by one until the problem comes back.
If this doesn't work either, try disabling McAfee (if this is possible, and bearing in mind the potential risk) and then see.
15-04-2014 12:42 PM
E mail, any sugestions
07-05-2014 10:56 PM
The McAffee forums say to disable real time scanning of email attachments; which does indeed sort the problem.
However, how safe is this?
07-05-2014 11:31 PM
McAfee may fix the problem in time.
08-05-2014 10:27 PM
09-05-2014 1:12 AM
10-05-2014 12:15 PM
10-05-2014 8:20 PM
14-05-2014 8:47 AM
14-05-2014 11:48 PM
That should do it.
According to spraxyt, this does not compromise safety. I bow to his greater knowledge.
15-05-2014 7:56 AM
15-05-2014 3:14 PM
( "C:\Program Files\McAfee.com\Agent\mcagent.exe" /desktopicon /platui ) . It is via this second one that I get to the wanted menus.
I'm just assuming they both appeared on the desktop when I installed it. the second link is also present in the tray at the bottom right of the screen.
Good luck!
