Thunderbird Setup
BS6600
Thunderbird Setup
Sorry - old question but my laptop died, setting up new one and I'm missing a trick. I've read the help and previous topics but no joy
I can log in and read web mail on my tablet so I know my name and password bit TB says failed to find settings for my email account.
A typo probably but any help would be great
Bill
Can't work out how to paste a screen shot so attached docx
Moderator's note by Mike (Mav): Personal information removed from attachment in a public forum.
4 REPLIES 4
Anoush
Aspiring Hero
Fixes: 139
Re: Thunderbird Setup
Hi Bill,
The username you use for both incoming and outgoing mail should just be your username rather than your full email address.
SSL for both should be set to none and authentication set to password.
If you want to use SSL, select that for both and change the incoming port to 993.
I hope this helps.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
BS6600
Thanks - it was simpler - confusion on my part  between F9 and Force9
Fixed now
Anoush
Aspiring Hero
Fixes: 139
F9 and Force9 should be able to be used interchangeably. Glad you got it sorted though Smiley
Mav
Fixes: 515
Moderator's note by Mike (Mav): The fix has been changed to @Anoush as per post #2.
Forum Moderator and Customer
