Temp size limit on e-mails ?
- Temp size limit on e-mails ?
08-07-2012 1:20 PM
I've not had any problems before, but today I'm getting a "temporary message size limit on server" every time I try to send.
I haven't seen an error of this type before and I've raised a support request for it but has anyone else noticed this problem ?
Re: Temp size limit on e-mails ?
08-07-2012 2:42 PM
It was only after trying to send it once again that I noticed that one of the destination address was incorrect - it should have been xxxxxxxxxxxx@hotmail.com, but I had entered it as xxxxxxxx@hotmial.com
As hotmial.com is a perfectly legal server address, I don't understand why the message did not go OK - to be followed by a bounce-back regarding the non-existent email address.
It looks as though PlusNet's email server was getting a bit confused.
I've advised PlusNet of this and, if they provide any useful comments, I will put these on the forum for information.
08-07-2012 3:03 PM
08-07-2012 4:44 PM
As explained above, it's turned out to be nothing to do with the actual message size.
If anyone does need to send large files, then the skyfile system works well and is free for reasonable quantities of date :- http://www.skyfile.co/
Phil
08-07-2012 5:20 PM
08-07-2012 8:25 PM
08-07-2012 8:38 PM
08-07-2012 8:50 PM
08-07-2012 8:56 PM
08-07-2012 9:26 PM
As mentioned, I'll report the feedback I get from PN support.
Phil
09-07-2012 10:42 AM
10-07-2012 12:02 PM
I've just updated your ticket - basically we're asking for more information from the spam service relating to the issues you're having there and will let you know as soon as we hear back.
10-07-2012 3:40 PM
So, is there something in the attachment that the Spam filters could be disliking or if it contains links, experiment by removing them etc. You could try zipping the attachment to see if that made any difference.
10-07-2012 3:43 PM
10-07-2012 4:02 PM
