Smart phone running Windows 7.5
- Smart phone running Windows 7.5
13-05-2013 8:51 PM
Does anybody know how I set up my phone to send and receive emails for plusnet please? I had to reset my mbile and lost everything. No instructions on Plusnet site.
Message 1 of 8
(2,336 Views)
7 REPLIES 7
Re: Smart phone running Windows 7.5
13-05-2013 10:34 PM
Does this help:
Just checked the settings on my Samsung S2 and I have the following:
incoming - mail.plus.net Port 110
Outgoing - smtp.plus.net Port 587
Message 2 of 8
(749 Views)
14-05-2013 10:55 AM
On my ZTE Kis
Same incoming but relay.plus.net port 25 outgoing.
Message 3 of 8
(749 Views)
14-05-2013 11:48 AM
I was using port 25 but after a problem I was advised by someone at PN to use port 110. I can't remember why but maybe someone can tell us if it makes any difference
Message 4 of 8
(749 Views)
14-05-2013 3:09 PM
The "official" outgoing server is relay.plus.net though smtp.plus.net is still supported. Plusnet accept connections on port 25 but mobile service providers often block access to third-party relays using that port. Plusnet also support port 587 and using that generally works from a mobile network.
When connected via a mobile network outgoing mail authentication needs to be set up for relay.plus.net. Authentication can also be used on home Wi-Fi so no need to change settings.
David
Message 5 of 8
(749 Views)
14-05-2013 10:30 PM
Thanks for that info. I remember now I was having problems and it was suggested I changed to port 587 which solved the problem for me.
Message 6 of 8
(749 Views)
24-05-2013 10:44 PM
Thanks everyone who replied to my email. However, I am still a little confused. I set the ingoing and outgoing to mail.plus.net & relay.plus.net respectively on my phone. Do I set the router to incoming 110 and outgoing 587? I have a TP-Link router - is the VCI and VPI the in and out port? What is the VCI and VPI?
Message 7 of 8
(749 Views)
25-05-2013 12:16 AM
VCI and VPI are to do with you broadband connection, nothing to do with email settings. Please leave them as they are (0 & 38) otherwise you will have problems with the whole Internet.
That's RPM to you!!
Message 8 of 8
(749 Views)
