Slight glitch using webmail on Google Chrome
- Re: Slight glitch using webmail on Google Chrome
16-08-2015 9:53 AM
I have noticed, since becoming a Plusnet member recently, that when composing a mail using webmail in Google Chrome, the text box overlaps the Subject line, to the extent where you cannot see what you're typing.
Not sure if this is the correct place to post this problem, but I'm sure a mod will move it otherwise.
Message 1 of 4
(948 Views)
3 REPLIES 3
16-08-2015 11:38 AM
Here's a screenshot to help
Message 2 of 4
(496 Views)
16-08-2015 10:06 PM
That looks a lot like this (https://community.plus.net/forum/index.php/topic,132546.0.html) long standing topic. Please take a look to see if it is the same or not.
That's RPM to you!!
Message 3 of 4
(496 Views)
17-08-2015 10:24 AM
Thanks, I did spot that whilst browsing through the forum. It seems that a quick vertical resize of the window cures this problem but doesn't solve it.
Message 4 of 4
(496 Views)
