Simultaneous email failures
- Re: 9 hours 13 minutes to MAC
10-07-2013 3:21 PM
10-07-2013 3:47 PM
However I would recommend "1&1 Instant Mail" for a thoroughly reliable email service with properly secure logins and no issues with access on mobile devices.
If you have an independent email account (i.e. not the one provided by your ISP), you can choose to have your own unique domain name for your emails such as "email@adriana.me.uk" or "adriana@your-surname.me.uk". Have a look at "Domains" to see what is available.
Having your own domain name for your emails and using an independent email provider, makes it much easier to change ISP as you don't get trapped into using the ISP provided email names which you would otherwise have to go around changing, if you ever left.
10-07-2013 3:50 PM
*edit* Just read over the account, it seems to be an issue with the address you're using to send from. The domain has no MX records set.
10-07-2013 3:56 PM
10-07-2013 4:04 PM
Let me know if you need anything clarifying.
Edit: just noticed that the domain registration has probably recently been renewed. I wonder if it's this that's triggered the problem?
10-07-2013 4:12 PM
Web mail broke too.
mail direct to my plus mailboxes was broken but is working now
8 hours 18 minutes
10-07-2013 4:17 PM
10-07-2013 4:21 PM
Have you seen Bob's reply - How have you diagnosed your problem as being Plusnet's fault rather than your domain registrar?
What domain are you using for email?
10-07-2013 5:07 PM
I am pursuing the issues with my domains, but it looks like the plusnet problem, if there was one, has gone away.
Thanks, those who replied.
