Settings to maximise chances of being able to send from other networks
- Settings to maximise chances of being able to send...
01-04-2015 4:17 PM
PT
Re: Settings to maximise chances of being able to send from other networks
01-04-2015 4:26 PM
You need to follow the guides here for SMTP Authentication
01-04-2015 4:42 PM
I should have said I am using a client usually outlook.
SMTP authentication as described in the guides does not always work. I have had some success changing the port to 587 but that is not infallible!
PT
01-04-2015 5:07 PM
01-04-2015 5:20 PM
01-04-2015 6:06 PM
If you have access to the command line/telnet then you can try telnetting to our relay servers and check the SMTP banner (you can use '587' in place of '25' in the following example to check that port too):
~$ telnet relay.plus.net 25
Trying 212.159.9.107...
Connected to relay.plus.net.
Escape character is '^]'.
220 avasout03 smtp relay.plus.net
If you see anything other than '220 avasoutXX smtp relay.plus.net' then something is interfering with the traffic.
02-04-2015 6:22 PM
At what kind of locations are you having problems? Open public Wi-Fi networks, over 3G/4G or on private corporate networks?
I use multiple devices configured with SMTP pointing at the PlusNet servers using port 587 using authentication (but NOT SSL) all over the place. Your PlusNet account username and password or username+mailbox-name and mailbox-password are the credentials you need.
I have though found issues on some business networks which (for the prevention of leakage of corporate data - as an example) do not permit any access to external SMTP servers. Also some 3G/4G networks (possibly down at cell level) do not seem to support alien SMTP access.
Exactly what error messages are you seeing? Do the configurations work on any non-PlusNet network?
Are your afternoon dropouts still fixed...?
Kevin
06-04-2015 7:14 PM
thanks for replying.
Settings do work on some networks. Problems I have are mainly with University networks and some mobile phone operators so I guess its just a security issue with them. I can get round the mobile networks by using gmail servers to send but this doesn't work at Uni.
Dropouts a thing of the past thanks. Not had one since line repair.
Jon
06-04-2015 8:09 PM
I'd have a word with the Uni IT people and see if they can offer a solution - ideally opening up port 587 in their firewalls.
As for the problem on mobile networks, is that over your phone? If you can profile that to particular locations, then I'd report the issue to the phone operator. Explain that it works on many locations, but not particular locations. Note what network type is being offered and is givining problems - 4G / 3G / E / GPRS
Kevin
10-04-2015 8:43 PM
Should include 2013.
