You'll need to give a few more details when you're setting up your email application. They can be pretty confusing, so here's what to use.
IMAP | POP | |
Incoming server | imap.plus.net | mail.plus.net |
Incoming port | 143 | 110 |
Outgoing server | relay.plus.net | relay.plus.net |
Outgoing port | 587 (recommended) or 25 | 587 (recommended) or 25 |
SSL/TLS | No | No |
SMTP Authentication (only needed if you're sending emails from a non-Plusnet Internet connection)* |
Yes | Yes |
A shot of my attempted settings is attached. The password has been entered several times, and as to SMPT authentication, there is no sign of the optiion being available.
What am I missing? Please help!
