Setting up email on android smart phone?
Luzern
Fixes: 9
Just graduated to a cheap smartphone. At home I use Thunderbird to receive and send messages on my PN accounts and also my gmail and hotmail accounts.
I'm showing my age and ignorance, I know, but can someone advise me the settings I need for the phone to enable receipt and senfing of emails? Please!
7 REPLIES 7
spraxyt
Resting Legend
Fixes: 75
Re: Setting up email on android smart phone?
There is a generic set up guide for Android devices here. Specific settings can be found on your Member Centre Connection Settings page. You will probably find using the IMAP incoming server works best for you.
David
Luzern
Fixes: 9
Links bookmarked for use at convenient time. Thank you! Smiley
Luzern
Fixes: 9
From instructions is
Your email username and password
Setting up for the first time?
Email username: Your Account username
Email password: Your Account password
Your Account username and password are the ones you log in to this website with.
Setting up an additional Plusnet email address?
Email username: Your mailbox username (in the format username+mailboxname)
Email password: Your mailbox password
I think that's saying that username@ username.plus.com has to be set up willy-nilly and only after that can separate IDs and mailboxes be created.
Is that correct?
Oldjim
Resting Legend
Fixes: 63
No you can just set up the additional ones but then it won't pick up those from the default email
I have never ever used the default one which wasn't even there when I first used the email
Luzern
Fixes: 9
but for some reason (me or other Roll_eyes Smiley ) I tried to use only the mailbox personal to me and the whole lot was rejected.
Oldjim
Resting Legend
Fixes: 63
I assume that you did use the format username+mailbox name
I set it up on my better half's tablet with no problem
Luzern
Fixes: 9
Whatever it was I've got it going now. Grin
