Setting up email on Samsung Monte S5260
philewer
Help needed please! I cannot set up email on Samsung Monte. I've tried every possible combination of username and password (I am using  a mailbox) but I keep getting message"invalid login". Any clues as to what I am doing wrong?
2 REPLIES 2
spraxyt
Resting Legend
Fixes: 75
Re: Setting up email on Samsung Monte S5260
If you login to the Member Centre and go to Webmail can you login to the mailbox there? If you can make a note of the Name format (ie username and account password or username+mailboxname and mailboxname password). If you can't login, it is most likely that the password is wrong. If necessary you can reset the password using Manage My Mail.
The same Name and password should be used for collecting mail on your mobile device.
More about email addresses in Email addresses explained.
David
philewer
Many thanks. This was very helpful and I've now managed it! Smiley
