Setting up email from my own domain using relay.plus.net
- Re: Setting up email from my own domain using rela...
28-04-2014 2:22 PM
I've finally managed to set up my own domain email to send messages via relay.plus.net on my Windows 8.1 notebook (using Windows Mail) and my Android tablet.
For this to work I have had to remove authentication and sign in from outgoing settings. i.e. I have un-ticked "my server requires authentication" and therefore have not entered a username and password for outgoing mail.
I'm pleased I can send mail, but am now concerned that I have left things rather vulnerable. I tried with "my server requires authentication"ticked,and then entering my plusnet account username and password, but this did not work.
I do not have a plusnet email address (well, there might be one, but I have never used it)
Have I done the right thing? Have I left my email vulnerable? Should I go on a computer course? (I seem to spend hours on this topic every time I change any technology)
Message 1 of 4
(1,589 Views)
3 REPLIES 3
Re: Setting up email from my own domain using relay.plus.net
28-04-2014 2:33 PM
Regarding outgoing mail - there is no security risk as you don't actually sign in to send mail only receive it
Message 2 of 4
(896 Views)
28-04-2014 2:36 PM
Thanks for that quick response - I'll just leave everything as it is then.
Message 3 of 4
(896 Views)
28-04-2014 2:47 PM
However, you will only be able to send email when you're at home i.e connected to your Plusnet router. If you need to send email when away from home, say connected to a free wifi hotspot, then you will need to use authentication.
Although your PN username/password should work, I suspect you need to have a PN mailbox for it to work, so it might be worth creating one ( even if you don't use it!).
See the authentication smtp setup guides here http://www.plus.net/support/email/setup/ .
Note, once you've setup authentication it will work both at home and away.
Message 4 of 4
(896 Views)
