Sending emails away from home
- Sending emails away from home
05-08-2012 5:34 PM
This time, the failure is affecting two computers both using Windows 7 and Live Mail.
I can receive emails, but not send them.
I can send using webmail, but not through a non-home setup abroad.
I have followed the instructions how to "Send email from any connection" on the Plusnet website step by step.
I have also changed the relevant port settings from 25 to 587 as suggested in an earlier email on the forum.
But still no success.
Even after having followed the instructions, and clicking to Use same settings as my incoming server, I am getting asked to authenticate the settings.
Any help and suggestions would be much apprecaited.
It should be so strightforward, but it is not.
thank you.
Simon
Re: Sending emails away from home
05-08-2012 5:44 PM
05-08-2012 6:23 PM
I am using a wifi connection in a holiday home overseas and I have no details of which ISP is being used.
I can connect to the web, get emails in but not send them.
My Blackberry is both receiving and sending email messages using the wifi fine.
It is just these 2 laptops which will not send.
Thank you once again.
Simon
05-08-2012 6:26 PM
Regarding the ISP you are using try using the Tracert command from a DOS window and the second hop, after the router, should tell you which ISP it is
05-08-2012 6:46 PM
Are you able please to talk me precisely how I get this.
I don't really understand DOS.
Thank you.
Simon
05-08-2012 7:00 PM
05-08-2012 7:03 PM
05-08-2012 7:26 PM
Go to Accessories
Select Command Prompt
This will bring up a window like the picture
Alternatively Go to the start menu and select Run - then type in cmd
It should have the same result
In the window type tracert bbc.co.uk
This is what I get and you will see that the second hop is Plusnet
Quote C:\Users\Jim>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 34 ms 32 ms 33 ms lo0-central10.ptn-ag04.plus.net [195.166.128.193]
3 33 ms 32 ms 32 ms link3-central10.ptn-gw01.plus.net [84.93.248.228]
4 32 ms 31 ms 31 ms xe-10-1-0.ptw-cr01.plus.net [212.159.1.44]
5 31 ms 32 ms 31 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
05-08-2012 8:26 PM
I have pasted the fist 6 parts of the trace below.
It appears to have timed out!
Simon
1 1 ms 1 ms 2 ms . [192.168.2.1]
2 1 ms 1 ms 2 ms 192.168.1.1
3 * * * Request timed out.
4 16 ms 13 ms 14 ms 194.107.134.161
5 13 ms 105 ms 12 ms 194.107.134.2
6 13 ms 106 ms 14 ms 213-153-33-110.dyn.salzburg-online.at [213.153.3
3.110]
05-08-2012 9:14 PM
smtp.salzburg-online.at
OR
smtpmail.salzburg-online.at
I'd try the top one first as I think it will be the more likely. These are to be set only in your Outgoing Mail Server settings.
06-08-2012 8:07 AM
Thank you for your suggestions.
I have tried both of them in my outoing server - and neither has worked.
Status has reamined the same, inbound messages are ok, but outbound messages are impossible.
Any new suggestions are very welcome - thank you!
Simon
06-08-2012 9:44 AM
06-08-2012 11:14 AM
Quote from: sherpa Even after having followed the instructions, and clicking to Use same settings as my incoming server, I am getting asked to authenticate the settings.
As you are getting an authentication error I would say this point to a setting problem and not the ISP of the connection you are using or a Port problem.
So I suggest reverting back to Port 25.
The username and password for the outgoing server are for the default mailbox which are ones that you use to log in to your Plusnet account. If you use mailboxes in the form of username+mailbox this format will not work for the outgoing server.
06-08-2012 1:46 PM
Quote from: itsme .... If you use mailboxes in the form of username+mailbox this format will not work for the outgoing server.
As long as the mailbox password is used the username+mailboxname form should, in fact, work on the outgoing server. However just username and the account password could be tried if the user feels security risk from plain-text transmission of passwords is minimal.
Authentication problems does make the problem seem like incorrect credentials.
06-08-2012 8:42 PM
I have tried every suggestion a number of times.
However when reverting to Port 25, and the normal Plusnet servers, I have had success with the suggestions from ITSME and SPRAXT.
It has worked.
I do use multiple email addresses, with their own usernames and passwords.
I reverted to the default set up - and Bingo I can send and receive properly.
Thank you!
To Plusnet - I do believe this needs to be clearly spelt out on your instructions for sending emails from other than home locations.
Simon
