Send Error. Plusnet in several DNSRBL?
- Send Error. Plusnet in several DNSRBL?
29-05-2014 12:57 PM
I'm receiving a few bounced emails reporting the following IP address is blocked: 84.93.230.250.
The reports all point to http://spameatingmonkey.com/lookup/84.93.230.250
But further checking of that IP shows other blocking lists hold it e.g. http://www.dnsgoodies.com/ then put the +Net IP in "Spam Database Check"
This is a snippet from the automated reply:
Paul.<><
A message that you sent to the following recipient could not be delivered due to a permanent error.
** The remote server 67.228.100.178 responded with: ** address@concealed.com 554:5.7.1 Service unavailable;
Client host [84.93.230.250] blocked using bl.spameatingmonkey.net; listed,
see http://spameatingmonkey.com/lookup/84.93.230.250
This message was created automatically by mail delivery software on the server avasout05.
Paul.<><
Message 1 of 2
(911 Views)
1 REPLY 1
Re: Send Error. Plusnet in several DNSRBL?
13-06-2014 2:06 PM
Seems to be OK now. I'm not sure the other blocklists are too much to be concerned about.
Message 2 of 2
(371 Views)
