Secondary mailbox
FIXED- Subscribe to RSS Feed
- Re: Secondary mailbox
17-01-2021 9:07 AM
Still doesn't make sense to me. IT IS IMPOSSIBLE TO HAVE TWO 'DOMAINS' - MYNAME.PLUS.COM & ENGINEER.PLUS .COM - unless you have two accounts with PN.
A further thought - have you left PN and then come back?
17-01-2021 9:15 AM
@jab1 yes it's impossible to have two .plus.com domains but I wonder...
@Brian9 do your secondary mail addresses actually end in .plus.com or are you just using that as an example. Since you've been with plusnet for some time , I wonder if you took up the free domain offer due to the email hack some years ago ?
17-01-2021 9:26 AM
@Brian9 do you log in to the same account to access both your email address something@username.plus.com and something@engineer.plus.com?
Also can you post up a screenshot of the entire browser screen showing something@engineer.plus.com listed in your account?
Might help identify how that’s been set up.
Make sure you redact personal info from the screenshot though such as your account username and whatever’s before the @ symbol of your engineer mailbox.
17-01-2021 9:58 AM
Thanks all
Yes my secondary email for example ##@engineer.plus.com (note: engineer is a made up name) ends in plus.com and in fact that's what used in registering for the community and plusnet send me an email to confirm my mail address of course I could have used ###@myname.plus.com as well.
17-01-2021 10:02 AM
Sounds like you have two login accounts...
17-01-2021 10:02 AM
In that case , I can only agree with John ( @jab1 ) here
You must have two accounts
17-01-2021 10:05 AM
Well as mentioned my oldest email saved using ##@engineer.plus.com is 12 years old
17-01-2021 10:07 AM
Do you log in to the same account to access both your email address something@username.plus.com and something@engineer.plus.com?
17-01-2021 10:08 AM
Well if I have two accounts how do I see my mail box for ###@engineer.plus.com?
17-01-2021 10:09 AM
You’d log in to the member centre using the username engineer and the password. Reset the password here https://www.plus.net/forgotpassword/ if needed
17-01-2021 10:25 AM
Thunderbird does it so for example for friend setup would be email address friend@myname.plus.com and server name mail.plus.net and user name would be myname+friend
and
for example vouchers would be email address vouchers@engineer.plus.com and server name mail.plus.net and user name would be engineeer+vouchers
17-01-2021 10:30 AM
Firefox remembers my passwords so no need to change my password to enter the community?
17-01-2021 10:35 AM - edited 17-01-2021 10:36 AM
I think there’s some confusion. You’d need to go here https://www.plus.net/member-centre/login
Log in with the username engineer and the password is the password for the primary engineer mailbox
on 17-01-2021 11:06 AM - last edited on 17-01-2021 11:37 AM by dvorak
You might have solved the problem as logged in with user name engineer and it's very old with dial up 😲 and added another email reply@engineer.plus.com but have to wait 30mins to see if it works. Hope it doesn't affect anything else as I just get one billing from plusnet for emails, internet use and phone.
Moderators Note: full quote of preceding post removed as per Forum rules
17-01-2021 11:12 AM - edited 17-01-2021 11:15 AM
It says that but the change is usually immediate. Try a test email to the new address...
Sounds like an old account that was converted to 'email only' (a free generic services account). Did you leave PLusNet at some time in the past and then return ? It's not possible to reuse an existing account when returning so a new one would have to have been created.
