SSL on IMAP/POP3/SMTP (again)
Fixes: 53
Re: SSL on IMAP/POP3/SMTP (again)
Hi @kmilburn,
The setup guides have been flagged and are being looked into so that an updated revision can be put in place.
To those in the thread that were wondering about the specific implementation date of this change, I'm afraid that we aren't able to confirm this. I would reassure you in saying that the change is now live and it is a permanent change, meaning it's not just some glitch or short term test that we'll revert in the next couple of weeks.
 Alex H
Please can somebody post the settings required to set up email using ssl
To receive I use:
     Server:  mail.plus.net
     Port: 995
     Connection security: SSL/TLS
    Authentication: Normal password
To send I use:
     Server: relay.plus.net
     Port: 465
I also have gmail which is the same apart from the server names.
Fixes: 43
Even though port 465 works it is deprecated. Please use 587.
Fixes: 7
I can’t get the ssl to work on port 587 using k-9. Port 465 does accept the connection. Is this just k-9 at fault or are there other clients not able to use port 587 & SSL?
That's RPM to you!!
When I set it up,
587 worked with TLS on old mail client where SSL and TLS can be selected separately, but can only use 465 for SSL
So if its deprecated then I am not sure what we port we can use if its removed in future.
Has anybody got 587 working ?
Maybe Plusnet are still rolling this out and haven't updated fully. Maybe Plusnet engineer can confirm ?
Fixes: 126
Port 587 will work with STARTTLS, rather than explicit SSL/TLS
Using Thunderbird, I can only use port 587 if I also select STARTTLS.  True for both Plusnet and Gmail
Having read up STARTTLS is less secure then SSL/TLS as it allows unsecured connection and transmission silently between client and server where the email server doesn't enforce TLS.
Please can somebody from plusnet confirm that plusnet email server relay.plus.net enforce TLS on port 587 ?
Two months later the instructions here: https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/#what-other-settings-do-i-need are still out of date.
Ex él Kent news! What a pity it has not been publicised more!
It's up to you to tell your client to use STARTTLS, and additionally some (most?) servers enforce it too. I run a small hosting service and my SMTP server comes up with this if I try to send mail (even for local delivery) with an unauthenticated connection:
550 Only authenticated connections are allowed on ports other than 25 (587).
...and it doesn't let me authenticate without encryption (set up via STARTTLS)
So STARTTLS is not inherently insecure, what you have read is that it CAN be set up insecurely, but so can anything!
For example, it's quite hard to get exim4 to allow authentication without encryption. It's certainly not the default configuration, and you have to read documentation with warnings about the security risks!
What about IMAP settings?
Also tried enabling SSL on outgoing relay (587) but did not work with Windows 10 email client.
Can somebody at PN please supply all settings for this!????
Fixes: 126
SSL for IMAP uses port 993
Explicit SSL on port 587 wont work, you either need to use SSL on port 465 OR STARTTLS on 587
Hope that helps
So what's the progress on this..
We're now 6 months later and the instructions are still out of date.
I may have missed it,   but I've not seen any announcement either,  still leaving most of you're customers in the dark and potentially vulnerable?
