SPF record using Freenetname
bobcox
I recently started to experience failure messages sending to BT internet addresses from my freenetname domain (bobcox.co.uk)
The failure message suggested that my message was from a bulk spammer address. I challenged the BT internet tech support:
Their response is as follows:
The domain "@bobcox.co.uk  " having no spf record. The traffic sent by such domain with no SPF record would be less. An SPF record is required to increase the traffic limit. No SPF record results in rejecting the mails once the counter reached its limit. but the domain holder should be made aware to modify their SPF records in-order to ensure timely delivery of mails.Kindly contact domain admin/ISP provider to set up spf record.
Please advise.
5 REPLIES 5
TheMightyAJ
Fixes: 126
Re: SPF record using Freenetname
Hi @bobcox,
I'm sorry to hear that you're having this issue. I've tried searching our systems for this domain, however I'm afraid that I've been unable to find it. Please can you send me a private message with the account username so we can investigate further from our side?
 Alex H
bobpullen
Fixes: 316
The Madasafish domain control system doesn't support TXT records, so what's been suggested isn't possible I'm afraid.
Fixes: 160
More to the point in the absence of a SPF record other service’s responses should be neutral - not aggressive as appears to be happening here.
fxbronte
Hi Bobcox
I have a very similar problem but my domain is domain.plus.com which is ironic.
bobcox
Hi AJ
Did you find anything during your further investigations please
