{SOLVED} Help with message being spam blocked
HairyMcbiker
All Star
Fixes: 21
I am trying to send a message to an insurance company.
The response I am getting back is this:-
Received: from relay.ptn-ipout02.plus.net ([212.159.7.36]) by
ixe-mta-22.emailfiltering.com with emfmta (version 4.8.3.54) by TLS id
622818794 for compaints@isurance.co.uk;c04ba5b4df13d24c; Thu, 01 Sep
2011 18:52:53 +0100
X-IronPort-Anti-Spam-Filtered: true
I have sent this using my gmail account and my plusnet account with the same block on it. Any idea how to get pas this?
6 REPLIES 6
spraxyt
Fixes: 75
Re: Help with message being spam blocked
Is that meant to be an unedited quote from the response?
Quote from: Hairy
I'd have expected compaints to be complaints including a lower case L, and though isurance.co.uk is a registered domain it looks to be 'parked'.
Should it be insurance.co.uk ?
David
ChrisL
Quote from: Hairy
This just tells you that the message has been seen by the spam filter. It is not saying that the filter blocked it. (Much more likely that the address wasn't recognised, as suggested by spraxyt.)
Best wishes
Chris
HairyMcbiker
All Star
Fixes: 21
No it was an edited version, I removed the "guilty" party's name since I didn't want to spam the mail box.
Hmm could be a spelling mistake, as I have said before I have slight dyslexia and sometimes miss spell things, and if the spell checker doesn't find it...
spraxyt
Fixes: 75
Usually the actual reason for the message being rejected (bounced) is included within the response - something like
Reporting-MTA: dns; pcl-ipout02.plus.net
Final-Recipient: rfc822;xxxxx@yyyyyy.net
Action: failed
Status: 5.0.0 (permanent failure)
Diagnostic-Code: smtp; 5.4.7 - Delivery expired (message too old) 554-'imta36.pppp.qqqqq.rrrrr.yyyyyy.net block for spam'.
... if it was being blocked for spam.
However since you've tried using Google and Plusnet some other explanation seems likely - misspelling the address seems a likely one.
David
HairyMcbiker
All Star
Fixes: 21
I resent it using the added "l" and it seems to have been sent ok.
Thanks all.
pierre_pierre
Re: {SOLVED} Help with message being spam blocked
these things are easily missed even for some one without dyslexia
