SMTP when abroad
fxbronte
SMTP when abroad
I use Windows Live mail 2011 and it works fine at home, however when abroad and using, say the hotel wifi, I can only receive emails, when sending I get a SMTP failure. Any ideas?
Thankfully I can still use Webmail, but I would like to use Windows live on holidays
10 REPLIES 10
kmilburn
Re: SMTP when abroad
It is probably the ISP blocking access on port 25,  PlusNet have recently opened port 587 so you can change your settings to give that a try.
One thing to bear in mind,  when using Windows Live all communications between you and PlusNet servers are not secure.  Using Webmail is secure.
bobpullen
Fixes: 316
You'd need to make sure you're using SMTP authentication as well as port 587.
journeys
@Bob:- Brilliant, thanks for that, been bugging me for years! I've set up temporary yahoo accounts to send from it was such a pain Embarrassed
Can I keep my email settings to using SMTP authentication as well as port 587 when using a PN connection or should they revert to port 25
jelv
Fixes: 10
If it works on a PN connection why would you want to change it?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
artmo
Aspiring Champion
Whilst in the US I could receive email OK but couldn't send to multiple recipients.  Bob told me to change my SMTP to the ISP I was using in the US and it worked a treat Smiley
journeys
Quote from: jelv
@jelv:- It works OK on a plusnet connection, but dosen't on other ISP's
@artmo:- I tried changing settings to the ISP where I'm connected, just dosen't work, even with port 587, then tried the port 587 with relay.plus.net as smtp and works a treat, multiple recipients as well.
I'd just about resigned myself to using a yahoo address then read this thread, Sunday Afternoon down to reading threads.......bit sad.
jelv
Fixes: 10
I meant if 587 works on a PN connection why would you want to change it back to 25?
journeys
@jelv:- Sorry misunderstood :D, the question was supposed to be "would 587 work on a PN connection". Guess the answer is yes Roll_eyes
spraxyt
Resting Legend
Fixes: 75
Yes port 587 works on a Plusnet connection (with or without authentication in this case). If port 587 and authentication are set there should be no need to change the settings between home use and roaming. Smiley
David
journeys
@spraxyt:- many thanks.
