SMTP server settings
- SMTP server settings
24-09-2014 6:34 PM
Could someone tell me what information I need to add in the Requires Authentication "Log On Using" box.
Re: SMTP server settings
24-09-2014 6:40 PM
24-09-2014 10:19 PM
There are other emails using Plusnet emails on the same Outlook Express user
This is from a Plusnet connection
24-09-2014 10:37 PM
24-09-2014 10:49 PM
25-09-2014 12:09 AM
25-09-2014 12:11 AM
25-09-2014 10:55 AM
25-09-2014 11:06 AM
25-09-2014 11:36 AM
25-09-2014 12:53 PM
Quote from: wingco1 Not using any authentication at all.
You will need to use authentication if you're not connecting from our network.
Edit: I'm on network but SMTP authentication using your account seems to work from here:
~$ telnet relay.plus.net 25
Trying 212.159.8.107...
Connected to relay.plus.net.
Escape character is '^]'.
220 avasout04 smtp relay.plus.net
ehlo avasout
250-avasout04 hello [84.93.219.165], pleased to meet you
250-HELP
250-AUTH LOGIN PLAIN
250-SIZE 104857600
250-PIPELINING
250-8BITMIME
250 OK
auth login
334 VXNlcm5hbWU6
[REDACTED]
334 UGFzc3dvcmQ6
[REDACTED]
235 ... authentication succeeded
25-09-2014 1:04 PM
The error message when sending to my Plusnet account is "Server Response: '550 my Plusnet email address recipient rejected - domain has no delivery address (DNS MX or A record)', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79."
25-09-2014 1:12 PM
~$ dig *******ms.plus.com mx
; <<>> DiG 9.3.4-P1.2 <<>> *******ms.plus.com mx
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 30463
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;*******ms.plus.com. IN MX
;; AUTHORITY SECTION:
plus.com. 3600 IN SOA ns1.force9.net. hostmaster.force9.net. 2014092523 6002 2580 604800 8640
;; Query time: 2 msec
;; SERVER: 84.93.219.251#53(84.93.219.251)
;; WHEN: Thu Sep 25 13:09:14 2014
;; MSG SIZE rcvd: 97
This won't stop you sending an email via relay.plus.net using your username and password though. You just need to ensure you're not sending from or too your newly created Plusnet email address.
25-09-2014 1:20 PM
25-09-2014 1:37 PM
You /can/ authenticate using your Member Centre details. As jelv has suggested though, until we offer SSL/TLS, you're probably better to create an additional mailbox with a separate password for use when sending mail.
e.g. create an additional mailbox here called 'smtp' and choose a unique password. You would then send email using the username 'username+smtp' (minus quotes and replacing 'username' with your actual account username) and the newly created password.
