SMTP server not responding??
- Re: SMTP server not responding??
18-02-2011 7:54 PM
This old problem has resurfaced in the past day and I am now unable to send outbound email via relay.plus.net being continually prompted for a username and password.
Whilst about six retries earlier enabled email items to be sent, the email is still sitting in the Outbound queue after thirty plus. I'll keep trying but wanted you to be aware of this
problem.
problem.
Message 1 of 3
(1,339 Views)
2 REPLIES 2
19-02-2011 2:13 PM
Now using an alternative SMTP server across the world whilst PlusNet gets this fixed. No problems!
Very pleased I have a back-up solution...
Message 2 of 3
(355 Views)
21-02-2011 8:50 AM
Quote from: gardencoaster I'll keep trying but wanted you to be aware of this problem.
There are no service-wide problems that I'm aware of. If there were then we'd have been inundated. I'd be interested to know what IP address you're assigned when you're experiencing these problems as that could be a factor. If you have a subscription account then your member centre username and password should work for outbound authentication (but you shouldn't need to use it if you're connected to our network anyway).
Message 3 of 3
(355 Views)
