SMTP relay.plus.net error 535 Too many SMTP auth failures
ricahrd
Hello,
Our email was hacked the end of last week and since then have been unable to send emails with the error
We did change the account (and therefore email) password as soon as we knew and incoming is still working ok.  Outgoing is also working ok via webmail so it appears that the hacker still has a machine constantly trying to send messages with our old password and jamming our ability to send with it.
We were hoping if it was left for the weekend it would sort itself out but we're now 5 days later and still unable to send.
Is it possible for support to look into this please and somehow block their IP addresses instead of blocking the whole account?
Many thanks!
6 REPLIES 6
adamwalker
Fixes: 221
Re: SMTP relay.plus.net error 535 Too many SMTP auth failures
Hi there @ricahrd, I'll take a look into that for you, could you send me a private message with either the username please so I can have a look into it for you?
 Adam Walker
ricahrd
Thanks @adamwalker
Unfortunately when I click on Private Messages I am told "You do not have sufficient privileges for this resource or its parent to perform this action."
Does the forum mod need to increase my privileges?
thanks,
Richard.
Fixes: 1,484
You should be ok now, if not another post should do it.
ricahrd
thanks, didn't work but trying another post to check!
outinthesticks
I have this problem too, is there a link anywhere explaining what I need to do? Thank you
Alex
Fixes: 13
I think 5 is the minimum number of posts you need to send PM's.
