SMTP problems
- Re: SMTP problems
SMTP problems
22-08-2019 7:08 PM
This afternoon I started getting an incorrect password on outgoing messages. This occurred across 3 devices. I have spent most of the afternoon trying to sort this, including deleting and 'reinstalling my email account, changing my password and talking to tech support (no help). I have now got to the position where outgoing mails work if going through my VPN which goes through my Plusnet router at home but fails if sent via my EE mifi device without the VPN.
Anyone else have problems?
Re: SMTP problems
22-08-2019 11:48 PM
What port have you configured for SMTP?
Some network operators inhibit access to remote SMTP servers on port 25.
Port 25 should only be used for MX to MX message relay. Message submission should be made on port 587.
Re: SMTP problems
23-08-2019 7:22 AM
It was 587 but I tried 25 as an alternative without any success. So 587.
Re: SMTP problems
23-08-2019 8:43 AM
In which case one has to suspect that the IP address of your EE mifi device is being treated as suspect. What are the first 3 octets of the device's IP address please?
Have you tried using the device somewhere else other than its current location? I have experienced variable mobile phone connectivity similar to your description … something which appeared to be mobile cell related.
Re: SMTP problems
23-08-2019 12:54 PM
The WAN ip address was 010.007.046 and I now have a message "authentication failed authentication rejected because the IP has poor reputation."
Is this the Plusnet mail server getting fussy?
I have used the mifi all summer with no problems before.
Re: SMTP problems
23-08-2019 4:10 PM - edited 23-08-2019 4:11 PM
That looks like the IP address of the connected device and not that of the EE mifi device's external address.
If that is the address of the EE mifi device then this looks like an EE networking issue.
Try running a
tracert relay.plus.net
Re: SMTP problems
24-08-2019 8:34 AM
213.205.241.nn
Sorry, I tried to save time by looking it up on the Huwei app. Google tells me it is as above.
I am now 60 miles from where this started and it is still doing it. Tethering to my phone on O2 is now OK.
Re: SMTP problems
24-08-2019 9:40 AM
@JW - any thoughts as to why connections to the smtp servers might be failing from that IP range, but are OK if the user uses a VPN service? This somewhat points to EE blocking access to the PlusNET relays or the relays refusing connection from this IP range.
Re: SMTP problems
24-08-2019 10:59 AM
I am cruising round the UK and so it will have been used all round UK coasts.
Re: SMTP problems
24-08-2019 11:01 AM
The VPN I am using is a private one going through my Plusnet router/modem at home and I guess reports my home public ip address.
Re: SMTP problems
02-09-2019 10:32 AM
@Townman: There's a few things that could cause connectivity issues over one network but not another. I know from past experience that EE have had restrictions in place on both port 25 and 587, but I don't know if they still have that in place these days.
If it's on the relay servers themselves, then there'd be a more descriptive message saying what's happening rather than an outright failure to connect. As seen elsewhere with the poor IP reputation messages that are occasionally reported.
Re: SMTP problems
02-09-2019 2:32 PM
Hi @DerekBeaumaris,
Can you please advise me on a Private Message the mailbox/email address you're having trouble with sending out.
Re: SMTP problems
02-09-2019 2:45 PM
Thanks to everyone who responded. The problem has now gone away. I have done nothing but move about 100 miles from where the problem started.
Re: SMTP problems
02-09-2019 4:58 PM
Glad to hear that it's all working fine now @DerekBeaumaris,
Let us know if anything changes please.
Re: SMTP problems
02-09-2019 5:47 PM
I would not hold your breath!! I have seen this on the EE network time and again. It works in some places but not others.
What would be interesting to know is when you see this issue, are you able to access smpt servers provided by other ISPs
