SMTP down (again)
- SMTP down (again)
SMTP down (again)
31-03-2019 9:01 PM
Getting this when trying to send e-mails:
"An error occurred while sending mail: The mail server sent an incorrect greeting: Cannot connect to SMTP server 212.159.8.107 (212.159.8.107:25), connect error 10060."
Also, the Portal is timing out and it's taking ages to log in to Community.
Both SMTP and Portal are timing out in ping and tracert.
As ever, no indication on the Service Status page.
Re: SMTP down (again)
31-03-2019 9:04 PM
OK, a bit more.
Well, this time is exactly the same.
01-04-2019 8:02 AM
Hi @thejudge,
Please accept my apologies for the issue with outgoing mail and logging into the community.
I'm not currently aware of any outages, are you still experiencing the issue? I have tested your broadband service which appears stable while operating with the estimates speed, this test has dropped the connection temporarily.
If you are still experiencing the issue, please log into webmail then try to send a test email and let us know if you receive an error.
Thank you.
01-04-2019 9:21 AM
01-04-2019 10:25 AM
Hello @southerner,
Sorry to hear this is happening, just for clarity so we can help further;
- Are you sending mail through Plus.net/webmail or the email client on your device?
- Have tried alternative browsers if you are using our webmail directly?
- Have you recently change you Plusnet password, if so you will need to enter the account username and mailbox password on the outgoing server authentication details.
Please let us know how you get on.
01-04-2019 10:38 AM - edited 01-04-2019 10:41 AM
Edit - It's working now, I just checked.
01-04-2019 11:34 AM
Ah Glad to hear that @southerner.
Should this occur again, please try webmail on you mobile data so that we can determine if it is solely client related.
01-04-2019 11:41 AM - edited 01-04-2019 11:46 AM
This very much sounds like an external networking issue - a data connectivity issue in the cell you were connected to.
@thejudge
You do not specify if you are connecting direct to the PlusNET network (from home) or by some other means.
Can you connect to other services successfully?
01-04-2019 12:10 PM
The issue (whatever it was) now seems ot have cleared, but it's curious that it should happen in an identical way to the last time. As far as I could tell, no other service or website was affected.
For info, I was connecting from home over +Net ADSL using Thunderbird as e-mail client.
14-04-2019 5:49 PM
I can't believe that this has happened yet again!
Portal unavailable, my webspace unavailable, ftp server unavailable, SMTP unavailable:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
Tracing route to portal.plus.net [212.159.9.2]
over a maximum of 30 hops:
1 2 ms <1 ms <1 ms 192.168.0.1
2 29 ms 28 ms 29 ms vl241.ptw-ag02.plus.net [84.93.253.120]
3 29 ms 29 ms 29 ms 84.93.253.123
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 etc....
Tracing route to homepages.plus.net [212.159.9.91]
1 <1 ms <1 ms <1 ms 192.168.0.1
2 29 ms 29 ms 28 ms vl241.ptw-ag02.plus.net [84.93.253.120]
3 29 ms 30 ms 29 ms 84.93.253.127
4 29 ms 29 ms 29 ms 195.166.129.176
12 etc...
Tracing route to ftp.plus.net [212.159.9.91]
2 29 ms 29 ms 29 ms vl241.ptw-ag02.plus.net [84.93.253.120]
3 30 ms 29 ms 30 ms 84.93.253.127
4 30 ms 29 ms 29 ms 195.166.129.176
9 etc...
Tracing route to relay.plus.net [212.159.9.107]
2 30 ms 28 ms 28 ms vl241.ptw-ag02.plus.net [84.93.253.120]
3 29 ms 29 ms 30 ms 84.93.253.127
8 etc...
Nothing has changed at this end in terms of config, permissions, etc. So what gives?
14-04-2019 8:08 PM
It's come back now, but it always does after a while. Would still love to know what's doing it though.
14-04-2019 9:48 PM
There are a number of fail points which can give intermittent ‘password’ failures - I’ve seen 2-3 in the last week or so. Sometimes it’s just one mailbox others 3-4. Typically a few minutes later it’s all fine.
