SMTP away from home
- SMTP away from home
SMTP away from home
20-01-2014 6:36 PM
Is there a way around the problem?
Re: SMTP away from home
20-01-2014 6:43 PM
20-01-2014 7:30 PM
$ telnet relay.force9.net 25
Trying 212.159.8.104...
Connected to relay.force9.net.
Escape character is '^]'.
220 avasout02 smtp relay.force9.net
quit
221 avasout02 smtp closing connection
Connection closed by foreign host.
$ telnet relay.force9.net 587
quit
Are you sure it's not a local issue? As MisterW says, 587 would likely be your best bet (and presumably you mistyped port 21 rather than 25?).
Mathew
20-01-2014 8:46 PM
Both using Thunderbird with 'Authentication method: Password, transmitted insecurely' and 'Connection security: None'.
[Later] I can Telnet into both ports.
20-01-2014 10:36 PM
Edit: This might help with testing.
21-01-2014 8:35 AM
Hope that helps
21-01-2014 9:14 PM
Quote from: MJN The server isn't refusing connections on those ports; it's the authentication that's failing. I'm not a user of PN's SMTP server so cannot advise further however a hunt through the forums should reveal the correct username/password combinations.
Thanks.
The username and password I'm using are both correct. I tried your link and authentication failed when I entered the password. Clearly, something odd is going on, so I've raised a ticket. Current response time is 50+ hours!
22-01-2014 8:24 AM
