SMTP Response: 535 Too many SMTP auth failures. Please try again later.
MF2020
I'm using the latest version of Thunderbird on Windows 10.
Plusnet sent me an email on the 01-Jun saying that it was likely my email account had been compromised; they suggested I change my email password.
I logged into my Plusnet account and changed my account and email passwords.
Since then Thunderbird (and from today my iPhone) have been intermittently reporting problems when I attempt to send emails; it fails more often than not. The error is:
SMTP settings in Thunderbird are:
Server: relay.plus.net
Port: 587
Connection Security: STARTTLS
Authentication method: Normal passwod
Username: My email address
Webmail is fine.
Does anyone have any ideas?
Malcolm
2 REPLIES 2
Fixes: 146
Re: SMTP Response: 535 Too many SMTP auth failures. Please try again later.
Hi Malcolm,
A warm welcome to the forums.
Given your description, I would guess that the party who have compromised your account are still trying to access it with the old password.
@JW - can you advise please?
JW
Plusnet Staff
Plusnet Staff
Fixes: 24
That looks to be the case. It will, most likely, resolve itself when whoever has been trying to use it realises that the details are now failing. Given that could take some time, I've flagged it to the team who looks after these things to see if there's anything they can do in the short term to stop the IP addresses that have been trying to use your account from accessing the platform.
 Jon W
