SMTP Relay.
- Re: SMTP Relay.
SMTP Relay.
30-09-2013 4:25 PM
Wonder if you can help. I was wondering whether Plusnet have an SMTP server I can relay my domains email though? I have 3 or 4 personal domains and an email server at home. I would prefer (even though I have a static IP) not to connect directly to other mailservers and instead have my mailserver relay it's outgoing mail through Plusnet.
Is this possible? Do I need to auth against the server or is it just restricted to PN IP ranges? DO I need to provide PN with a list of my personal domain names that I want to send email for?
Thanks in advance!
S
Thanks in advance!
S
Message 1 of 2
(1,130 Views)
1 REPLY 1
Re: SMTP Relay.
30-09-2013 4:51 PM
http://www.plus.net/support/customer_service/using/settings.shtml
The relay server is relay.plus.net No authentication is required...
Message 2 of 2
(625 Views)
