SMTP Problems
johnscone
SMTP Problems
Hi I cant seem to get mail on OSX Snow lepoard to send mail tried relay.plus.net . All is exactly like the set up guide .Error message cannot send message using server Plusnet relay.
Everthing works ok on squirrel mail
Any help would be appreciated
4 REPLIES 4
ReedRichards
Seasoned Pro
Fixes: 25
Re: SMTP Problems
I'm experiencing the same problem at the moment; presumably Plusnet's SMTP server is not working properly.
ReedRichards
Seasoned Pro
Fixes: 25
Re: SMTP Problems
But working again now.
johnscone
Re: SMTP Problems
yeah working now
cheers
Pete4
Re: SMTP Problems
