Running Exchange server at home
rtho782
Seeing as Google apps is now paid, along with Windows Live custom domains, I've set up an Exchange 2013 server at home.
I've got it working and can receive mail, I've pointed the MX record to my static IP.
I've got outgoing mail working, but my emails seem to be filtered as spam by gmail based accounts.
I think this could be due to rDNS (I have it set to another of my domains at the moment, I have a ticket open to change it over but that could take a while), but it could also be that the IP is registered to Plusnet in the RIPE database or something.
Is there anything other than setting the rDNS that I can do to avoid my mail being classed as spam?
12 REPLIES 12
Fixes: 1,483
Re: Running Exchange server at home
this gives good pointers as to what is causing it http://www.allaboutspam.com/email-server-test/ and http://mxtoolbox.com/SuperTool.aspx can be useful too.
avatastic
You could add SPF records to the domain (unless it's hosted with Plusnet, as I don't think they've implemented TXT records yet?), set up DKIM and anything else that's been added over the years to say "Yes this IP address is the legitimate mail server for this domain".
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
bobpullen
Fixes: 316
I'd personally recommend you don't send email directly from your machine. Even if you take care to configure matching forward/reverse DNS etc. you'll not escape the fact that the IP we assign you will almost certainly be on a number of policy block lists like the one here. This means that you will probably encounter problems when sending messages to MTA's that spam-score or choosing to defer/reject mail from IP's on this list.
A much sounder solution would be to relay/smarthost outbound messages through the Plusnet relay servers.
I've just changed your rDNS.
rtho782
Thanks Bob, that makes sense.
Any help configuring the send connector in exchange 2013 to send via your relay? Smiley
It doesn't seem obvious...
jelv
Fixes: 10
Does this help? http://lmgtfy.com/?q=exchange+2013+send+connector+outbound+relay&l=1
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rtho782
Thanks for the passive aggressive LMGTFY response Wink
I've not bothered as with rDNS and TXT records, my emails are no longer getting marked as spam Smiley
MJN
Fixes: 5
It is only a matter of time/destination...
As Bob says, your IP will be listed on a number of blacklists and different destinations will attach different significance to such an entry.
jelv
Fixes: 10
If he's changed it to use the Plusnet relay it won't matter if his IP is on the lists.
MJN
Fixes: 5
My reading of post #6 was that an outbound relay hasn't been configured on the basis that the rDNS/TXT records had seemingly removed the spam trap triggering.
jelv
Fixes: 10
I read quite the reverse - he's done the relaying which has fixed the problem and so hasn't bothered adding rDNS and TXT
MJN
Fixes: 5
An ambiguity only the OP can resolve I think!  Grin
pwatson
There's no ambiguity
Quote from: rtho782
He's setup rDNS and TXT records and he believes outgoing email is not marked as spam.
Alternatively, with a couple of extra words and a comma:
I've not bothered [with configuring a relay] as, with rDNS and TXT records, my emails are no longer getting marked as spam Smiley
