RoundCube not showing full contents of email inbox
- Re: RoundCube not showing full contents of email i...
Re: RoundCube not showing full contents of email inbox
03-03-2012 8:55 PM
03-03-2012 11:03 PM
04-03-2012 8:26 AM
04-03-2012 3:48 PM
I've been on webmail several times today. However since it's a weekend there's been little Spam. I however decided to look at my Spam box which at that point had no number showing against it. When I clicked on it it immediately changed to "Junk (1)" and there was one unread Spam email in there.
So the problem re showing the wrong number of emails isn't just confined to the Inbox.
04-03-2012 6:40 PM
04-03-2012 6:56 PM
08-03-2012 8:11 PM
EDIT - number corrected
12-03-2012 9:49 PM
14-03-2012 5:44 PM
15-03-2012 1:19 PM
I appreciate it's frustrating but there's nothing we can investigate based on the information you're updating here I'm afraid. Is there any more information you can supply? Do folders show differently, or are there any other discrepancies you can see?
15-03-2012 1:54 PM
There are several issues here - and they may be connected:
A] The full contents of the inbox not being shown as the topic title
B] The number of unread emails not being correct - potentially related to A
C] The number of unread emails varying between SM and RC
"Do folders show differently" - I'm talking about the Inbox rather than any sub-folders. I've posted numerous screenshots showing differing contents. I haven't noticed any problems with sub-folders (apart from the Spam folder not showing unread emails some times) but then I don't use them much, usually downloading to Outlook Express. I also today noticed an email as unread in the Deleted folder - normally emails are marked as read even if block deleted so I don't know how that happened.
Today's experience: I've just logged onto RC at work (XPSP3 - Chrome) hence my visit here. The screen reported 46 unread emails - I clicked on "Inbox" and it immediately changed to 53.
18-03-2012 6:41 PM
18-03-2012 8:58 PM
Just a thought really, I'm not trying to say anything. Figuring out a pattern is part of the way to solve this.
18-03-2012 9:01 PM
18-03-2012 10:37 PM
I've not actually looked at the code for RC so I'm not too sure how it's accessing the imap server. So looking for the "trigger" is all that can be done, for the moment.
What can you do to help? Umm... If possible could try to have all those eBay messages go into a different mailbox, temporarily of course, to see if that mailbox runs into this issue and the previous mailbox does not encounter it again. Obviously if that's not possible then ignore that.
