Retaining and forwarding emails
ianmcleod1963
OK, I've just installed a CCTV system which sends alerts via email. This can only be set to one address so I've used my plusnet account. I would like an alert to go to my wife as well. Looking at a redirect it would send the email to her address if set up, but I would no longer get them as well. Anyone any idea how I can set up so that email sent to a specific email address gets retained but also forwards to another address?
3 REPLIES 3
spraxyt
Resting Legend
Fixes: 75
Re: Retaining and forwarding emails
Yes, as you said using a redirect would simply send the single copy of the email to a different address.
If you use an email client (eg Thunderbird or Outlook20xx) on a PC/laptop that runs most of the time you could create a message rule/filter that copies that email on arrival to a different mailbox.
Alternatively an external provider (probably a paid-for one) might provide this option. I think free ones are likely to provide simple forwarding rather than the store and forward combination you require.
David
Fixes: 151
Alternatively create an email address specifically for this purpose and set up all of your devices to read that mailbox.
jelv
Fixes: 10
Create a gmail email account. Then create multiple rules to forward the email to both of you.
See http://www.nordicblueconsulting.com/forward-emails-multiple-recipients-gmail-google-apps#.Wtok5Jch3R...
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
