Removing Boob spelling of Log In names?
colintivy
I am not sure if this post is in the right place, please divert it if necessary.
When I try to log in to Webmail, the system offers to fill in the details for me. The proper pair are there OK but the result of finger trouble two incorrect spellings for my log in name have also shown. I have tried to delete them but cannot find  where they are stored in the works with the ability to do it. Any clues?
Huh
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 29
Re: Removing Boob spelling of Log In names?
colintivy
Thanks @Gel!
I am on Win7Prof and have tried deleting with the cursor alongside the erroneous entry which does indeed disappear. But logging in with the proper text, the duph entry just reappears. Recently all the usernames acquired a new symbol like a key for some reason. I will fiddle some more.
Colin
Wink
rongtw
Fixes: 12
@colintivy  the key is your browser telling you its not secure site Thumbs_Up
if you are using Firefox to remove saved log on details,,  go top right 3 lines , Options / security /saved  logins / click on show passwords ..............  then you remove what you dont use Smiley
colintivy
@rongtw
Big Thanks!!
Hi! I would not have found that cure in a months time. Yes deletion very painless. I should have mentioned that I use Firefox as well as Win 7 Knuppel
This is the best use of the forum I know.
Colin.
Thumbs_Up Azn
