Relay not working
- Re: Relay not working
Relay not working
29-10-2012 9:13 AM
Not getting any response from relay.plus.net at present. Can someone give it a kick?
Message 1 of 6
(1,119 Views)
5 REPLIES 5
29-10-2012 9:23 AM
Well if you check the Service Status then everything is hunky dory but phone Technical Support and a recorded message says different. That's not very good, is it?
Message 2 of 6
(452 Views)
29-10-2012 9:30 AM
phew, thats good in some ways I guess. Just upgraded to windows 8 pro and cant send using OL2010. error message re interruption of connection all the time.
Message 3 of 6
(452 Views)
29-10-2012 9:30 AM
And now it's working again.
Message 4 of 6
(452 Views)
29-10-2012 9:38 AM
yep
Message 5 of 6
(452 Views)
29-10-2012 9:49 AM
Quote from: ReedRichards Well if you check the Service Status then everything is hunky dory but phone Technical Support and a recorded message says different. That's not very good, is it?
No, that message should have been removed
I'll ensure somebody attends to that now ...
Message 6 of 6
(452 Views)
